Capless fuel fill neck
Why is the screw style better than capless?
The capless saves time, reduces fume and vapor escape into the environment, maintains a completely sealed system until you gas up, the seal is designed to prevent contamination, and no more check engine lights if you don't put the cap on properly.
Guys up North will be happy not to have to contend with frozen gas caps in the winter.
I haven't had any problems with it.
