Green drips in snow under 2010
Under the truck, near front of drivers floor area there was neon green drips in the snow under my truck. First thought was coolant but the coolant isnt green. I cant figure it out. Been sitting in the same spot last night till noon today. What would that be? My first thought would be coolant but that far back? Anyone else have similar issue that may have input? My entire truck is dripping wet underneath from the weather so it was impossible to see where or what it might have been.
My 30k 2010 with 4,500 miles leaks, yet my brothers 2000 civic with 200,000 miles leaks nothing.. WTF!
Just rusty coloured water dripping down?
What does it smell like?
What does it feel like?
Did you have it undercoated?
Put her in the garage, dry it off for a day and then crawl under with a good light and see if you can figure it out.
Let us know how you make out, good luck
Dont have a garage and we are in the middle of a huge snow storm. Smells like carb cleaner sort of, cant tell the feel its in the snow, its bright neon green. No undercoating, no rust.
posted this on another ford site freon from a/c unit seems to be what people are thinking.. my defroster has been on since its the middle of winter, maybe came from that?
Ive seen what your talking about before and this is definitely not that. Its bright green and definitely leaking from somewhere by the firewall.
"95 per cent of the exhaust systems built today are made up of iron alloy and galvanized steel. Exhaust pipes are made of either iron or stainless steel. Heat shields are made of galvanized steel. Galvanized steel uses zinc as a rust inhibitor.
Zinc, when hot and in the presence of iron and a catalyst, creates yellow zinc oxide in the form of crystals. The connection is the catalyst – salt water – or compacted snow with road salt mixed in. If the snow is able to touch the exhaust heat shields and the exhaust pipes at the same time, the chemical reaction between the two dissimilar metals creates the bright yellow crystals."
My new 2010 does it, my old 2001 f150 did it. My wife's explorer does it. My friends CR-V does it. My dads Lexus does it.
Check the fluid levels but there are no neon green/yellow fluids in the new F150 I am aware of. Bring it to the dealer if you think you have a leak just to be on the safe side. Good luck, hope its nothing serious.
Not saying its that definitely but 99% of the time I bet its the case:
Two different people have given me a procedure to try so as soon as snow storm stops im going out to try and see if this is the case.
gotta love finding a leak on a brand new truck with under 5,000 miles..
Hopefully its minor and ill get it figured out soon.
