Leaking power steering pump
Hey guy,
Noticed red oil on the driveway the other so took the truck in for some service and a look at what was leaking. One my 2009 FX4 Screw.
I was thinking tranny (red fluid) but dealer telling me its the power steering pump hose is leaking... but its not the hose, its the pump assembly leaking at the hose. With my truck 2000mile out of warranty, dealer throws a $500 part bill my way. Not impressed really.
Anyone else see this?
Have not heard many complaints about this, don't think its common. Sucks you where 2000 over warranty, sometimes they will cut you some slack if you just a bit over. $500 to replace a hose seems a bit excessive but I assume that includes diagnostic fees, etc...
Buy a 2011, no fluid or pump...electric power steering
i see a power steering fluid reservoir on my week old 2011 Lariat
was that Brandon ? i have heard good things about them and can't believe they did not try and work with you being only 2000 over
If you have the 6.2L you do have a hydraulic power steering module. If you do not, you are mistaken as all 3.5, 3.7, and 5.0 equipped trucks have the eps and no fluid reservoir.
I have an 09. I had a power steering switch replaced because of a leak. Not sure if its the same piece. I didn't even know it. They told me when I took it in for a state inspection. It was covered under warranty. But I only have 22,000 miles on my truck. My truck has a lift. Thought maybe they would try to blame the lift some how. Sorry about your issue. It sucks to have to pay that kind of cash just cause some faulty piece of equipment.
My truck is an 09 5.4L.
