Wow the Ecoboost sounds weak!
With brake torqueing, you can do some great burn outs, my brother's Buick Grand National is proof of that!
you can buy 1 of these gadgets for that "v8 sound"
http://cgi.ebay.com/SoundRacer-V-8-R...item4cefb7ec7c
Once people get brave/crazy enough to start modding ecoboost f150s and running more boost they won't need to brake torque either.
It will happen, but not if you're running the stock psi of boost.
It must be a fairly stock GN if he needs to brake torque it to do burnouts.I run alcohol injection w/25psi of boost in mine and I can light'em up at a 35mph roll.
I started out in it, gave it a lot of gas and I was thinking this wasn't much. Just then the boost kicked in and I sided the car out and did a 180 degree turn "without the steering wheel". From then on out, turbos scared me.
He most likely didn't have to brake torque, but he did like to fill the area with smoke. Tires do get expensive after a while though.
