Grille Question
The bolts on the inside that you can see are the easy part.... maybe stop by your dealer and as if they have any other grills in stock. Make the parts guy think that you are going to buy a lariat or platinum grill, whichever they have in stock, and look at the clips before you attempt to remove them from your truck.
They're tough. I've been doing bodywork for 16 years, and I broke one of the clips the first time I took one of these grills off.
Good luck.
Yes Beach it can. The biggest challenge you will find is getting the grill off the hood. The clips are very tricky, and hidden, with a retaining "finger" on each side of the tiny slotted hole in the hood. Small clips, tight spaces. Most who attempt it break the tabs off the surround that the clips first slide onto. My advice to you is if you are not a bodyman with the proper tools..... find one.
Good luck.
Good luck.
just take your time. you must pinch the clips one by one starting on the outside and moving in. it can be very tricky but if u do break the clip don't worry to much about it because the bolts will hold the grille in place and there is no difference in look whether its broke or not. Good luck
