Mileage increase. Air intake, highflow muffle, gott mod, other? what has worked?
The major factors in MPG improvements are free:
1) Carpool
2) Drive the speed limit and no shotgun starts
3) Air you tires up to maximum sidewall pressure
http://www.gassavers.org/
1) Carpool
1) Carpool
1) Carpool
Ill disagree with number 3. I wouldnt go that far. because if you inflate to the maximum sidewall pressure, then what happens when you drive around and the tires heat up and the pressure increases? then you are over the maximum. I have always gone about 4-5 psi below the max rated tire pressure so that when im heated up im sitting right about the max.
You will find that your MPG will be a bit better and your tires will last a lot longer.
And it's freeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee.
Actually, lowering it will give slightly better mileage as will a bed lid. Nothing will pay for the mod except the freebies.
