Stowable bed extender and Bedrug combo - anyone have this?
Old 12-21-2011, 12:39 PM
BMWBig6's Avatar
What was left behind after you cut off the nubs? Just a hole? (The bed extender looks like hollow blow-molded plastic to me.)
Old 12-21-2011, 01:07 PM
05supercrew's Avatar
Yes just a hole but its small.
Old 12-23-2011, 10:07 AM
I found a sheet of little flat rubber pads the size of a quarter to cover the holes to make everything look a lot cleaner.
Old 01-31-2012, 06:06 PM
Sorry for bring a post back from the dead but I finally got around to taking pics of the bed extender with the rubber nubs cut off and a little rubber cap to cover the holes. For those that are interested.
Old 01-31-2012, 06:59 PM
BMWBig6's Avatar
Very clean! I ended up doing the exact same thing, but your rubber caps look better than mine (mine are flush). Do you have a close-up of the rubber caps (what are the from)?
Old 01-31-2012, 08:09 PM
I took this with my phone so hopefully it comes out ok. These are little rubber pads you would put under electronics in your home like dvd player, amp, cable box ect. Ive had these for years sitting in a draw.
Old 02-01-2012, 07:20 AM
BMWBig6's Avatar
Awesome, thanks for the pics. So these have an adhesive backing that you just peel and stick?
Old 02-01-2012, 09:00 AM
Thats correct, I glued them on just to make sure they dont come off.
Old 10-17-2013, 04:27 AM
ruffn-it's Avatar
Bringing this thread back to life to check on something. Was about to purchase an extender off another forum member, but he does not have the plastic grommet sleeves or whatever you call them that the pins push into. Are those plastic grommet things needed. I think i found the part number for those sleeves but they also say they are for the sport track and 08 and under extenders. I also have the bedrug so did you guys just poke holes in the carpet to push the pins through?
Old 10-17-2013, 09:10 AM
gDMJoe's Avatar
ruffn-it - ]Bringing this thread back to life to check on something. Was about to purchase an extender off another forum member, but he does not have the plastic grommet sleeves or whatever you call them that the pins push into. Are those plastic grommet things needed. I think i found the part number for those sleeves but they also say they are for the sport track and 08 and under extenders. I also have the bedrug so did you guys just poke holes in the carpet to push the pins through?
Quick Reply: Stowable bed extender and Bedrug combo - anyone have this?
