Electronic Gear Selector...
OP,
Manual shifting does not hurt anything. A common complaint of the 2009-2010 6-spd was the lack of control, especially when towing. You can lock into 1,2,or 3, but not anything higher. Many people found even in tow/haul mode, the transmission would shift into a taller gear, not be able to hold it, then downshift, rinse, repeat. 2011 offers both manual shifting to hold any gear, as well as range select which allows the transmission to shift into any gear you chose and below.
2011 - Tow/Haul only changes how the engine shifts and you still have the OD. I haven't played around with this yet, but from what I understand I should be able to hear the different rpm revs and when the shifting occurs... especially when towing something.
Manual allows you to stay in one gear at higher rpm if you wish. Not sure if I'll even use this.
To the o/p, what's the benefit of manually shifting the transmission in the city, unless you're looking for more performance off the line?
No need to listen for revs - just watch the gear indicator on the right-hand side of the screen. It tells you what gear you're in at all times, even in full auto mode.
