Please Help Key stuck in the bed tailgate.
Old 06-11-2011, 04:21 PM
artgarcia's Avatar
take off the panel on the inside of the tailgate, you should be able to get the key out with a little bit of patience
I think right now is the only way. Thanks!
Old 06-11-2011, 05:39 PM
fordmantpw's Avatar
^^^^^ what he said
Old 06-12-2011, 12:15 AM
artgarcia's Avatar
Just fixed in less than 5 minutes.
Inside the panel there is a plastic part and a metal one. the plastic part is a triangle shape and inside it is located a metal pin. The metal pin turns with the key and move the triangle.
The problem is the metal pin goes out of the triangle and it can't be moved. Just put the pin inside the triangle and know works just like new.
Quick Reply: Please Help Key stuck in the bed tailgate.
