Anyone pull any RV's with their 09+??
23 ft. Jayco, I think it's about 4500 dry. Dragging it with '10, 2wd, 5.4 w/3.55. After market brake controller, weight dist. hitch and friction sway bar. It does plenty fine. Mileage drops from 20-22 mpg to 10-12 mpg. I don't think I would want less of a truck in a hilly/mountainous region.
Yep, 2010 SC 5.4 2wd LS 3.55 pulling a 28ft around 5000lbs. I have the built in TBC and it works great, also have a weight distribution hitch with sway control. The factory sway works great as well, just use mine out of habit. Pulls great as I upgraded from an 07 4.6L that also did an ok job with the same trailer, but we wanted to do some longer runs
You would also want a 36 gallon gas tank at 7-12 mpg.
You should use a WD hitch if either the tongue weight or the gross trailer weight exceeds the rating of your standard hitch. Most Class 3 hitches have a 500 to 600# tongue weight limit and 5000 to 6000# gross weight limit. WD will increase this to at least 1000/10000#.
Wow L8PAPEX! I almost thought this was my truck and camper!!! ;-) I have a 2009 FX4 w/Max tow and I tow a 22ft Keystone Passport 200QS. My truck is the same color too.
