Need HELP.
Need HELP.
So i almost ran my truck into my shed. I had no brakes. Luckily i got the e-brake and stopped long enough to get it into park. So i get out of the truck and did a quick walk around and in the process of driving from my house to the shed which is 75 ft something happened i dont know if a rock hit it or what. Is there a way to cut out part of the brake line and put in a new piece? or buy braided lines to replace where i need some flexing because of my lift. It has a small crack in the brake line on the passenger side about a6 inches or some from the nut that goes into the actual brake caliper. This sucks!!!! Any idears?
I dont know.... I wonder if its defective. the truck only has a little over 13000 miles now.. I do zero offroading and only drive on gravel a rare occasion, but i cant imagine that a rock would have bounced around and hit it. a matter of fact where the crack is there is a rubber protective thing thats about a couple inches right below it, then it turns a 90 and heads toward the engine bay and all the way across to the drivers side(the stiff brake lines)
Yah no kidding! I guess this should have been put in the wheels. tires and brakes section...can someone move this for me? sorry.
Of course I am lifted, so i can only imagine what they will say about that. Ill try and see though In the mean timei was curious about a fix job. as i said before the truck isnt leaving my house anyway and im sure a ford mechanic isnt going to drive out to my house. i know brakes lines are pretty inexpensive and you can buy fitting and lines different lengths....
I was thinking id rather have a flexible brake line from the frame to my caliper long enough to bend and flex with the suspension better. from the frame to the caliper is a strange setup anyway with all the stiff tubing and new brake line hardware. I wouldnt mind seeing some other people brake line setups with there lift kits. I know i need to upgrade my brake lines so they are longer anyway, but just not sure which direction to go
I was thinking id rather have a flexible brake line from the frame to my caliper long enough to bend and flex with the suspension better. from the frame to the caliper is a strange setup anyway with all the stiff tubing and new brake line hardware. I wouldnt mind seeing some other people brake line setups with there lift kits. I know i need to upgrade my brake lines so they are longer anyway, but just not sure which direction to go or what all my options are
you can route it how ever you want. i just built all my brake lines on my landcruiser, wasn't to difficult you just need to use your head and see what will work and how you can secure them.
pull your wheel off and start brain storming, post up pictures of it and i'm sure some people will give you their ideas as well. doing hard lines is stupid simple, for my flex lines i just bought some off a LC vendor. napa is supposed to be able to make up flex lines, if not a hydraulic shop can. i'm sure summit or some place of the sort have them as well, you just need to know what size your fittings are.
not necessarily, depends on the dealership but brake lines are cheap enough where it's not worth the hassle to call around or drive to every dealer to find out which one that is.
