3" Level on 2wd = Clunking
It could be the Upper Control Arm hitting the coil spring on full droop, problematic with 09+ with more than 2" spacer lifts. Nothing can be done with that unless you replace the UCA with a Camburg Uniball, however you then can't use any rims with more than 4.75" backspacing (regardless of rim diameter) which negates any factory rims. But with that shallow of a backspace you may start to encounter significant tire rubbing issues with the fenders at full lock, depending on tire diameter.
