Did I make a mistake buying 3.55 gears?
Old 08-18-2011, 11:28 AM
2stroked's Avatar
Originally Posted by kschex
I haul a bass boat 2-4 times a month weighing around 3,500lbs.
What kind of bass boat weighs that much? Most bass boats I've seen are 18'-20' long and run 150-225 HP outboard. Even on a tandem axle trailer, I struggle with one weighing more than about 2,500 pounds. You should be able to tow that like there's nothing even behind you.
Old 08-18-2011, 12:33 PM
APT's Avatar
APT
APT is offline
Boats tow differently/easier than travel trailer RVs of the same weight.
While there are better options for a tow vehicle, it's expensive to change now. Run what you brung, learn from the experience, ask more questions before making the next decision.
Old 08-18-2011, 01:16 PM
kschex's Avatar
http://www.nitro.com/boat/specs.cfm?boat=3296
3000lbs. That is with 150 Opti I have a 175 ProXS that weighs more not including all the gear that is in boat when going fishing.
Old 08-18-2011, 01:26 PM
Except for the bridges way up there in Baton Rouge you don't have any hill's or mountain's to worry about! I pull a 22 ft Triton bay boat with no problem's so you'll be OK. Geaux Tiger's!
Old 08-18-2011, 06:05 PM
Roy Braddy's Avatar
3:73 gears
I had it figured out with my 2004 F150... It was a matter of gas mileage for me and towing more second.
I saw the other 3:55 guys got real good gas mileage but at the expense of power. I wanted to get both... The big trailer guys always used the 4:10 gears which resulted in less then 10MPG... So back then I got the 3:73 gears on my 2004 F150 and it had pretty good power and gas mileage as well.
When I traded trucks last year I made sure it had the 5.4 engine with the 3:73 gears... I am getting 18-21MPG pulling my 4200lb OFF ROAD POPPUP. Strange enough I get just about the same gas mileage without pulling the popup haha... I get my best gas mileage using Shell gasoline for some reason...
Old 08-19-2011, 06:50 AM
2stroked's Avatar
Wow, I have a 22' Progression with a 200 Merc that weighs right around 2,000 pounds. Of course it's vacuum bagged too. Must be those huge fish in the tanks!
Old 08-19-2011, 07:29 AM
kschex's Avatar
I am thinking Nitro is saying total weight is with the trailer and outboard.
Quick Reply: Did I make a mistake buying 3.55 gears?
