How Do I Remove the A/C Vent Louver in a 2011 XLT F150?
I need to take the A/C vent/louver cover off of my 2011 XLT F150 to get to the honeycombe piece behind it. The honeycombe piece is a bit loose and makes a chirping sound when I hit bumps due to the air flow through it. Mine have the chrome rings around the cover. There seems to be four tabs inside but I can't get it to budge or pull out. Anyone know how to remove this for a 2011?
Thanks.
Thanks.
stick your hand in the vent, grasp the louvers and pull straight out. the whole assembly will pop out: *be careful with the far left drivers side vent, the vent is in there tight enough you'll pull the colored dash piece with it. a third hand would help for that one*
live a little buddy. i had $20,000 of aftermarket modifications in a jeep with a factory suspension that was cut, re-welded and clearly gusseted with my factory warranty.
live a little buddy. I had $20,000 of aftermarket modifications in a Jeep with a factory suspension that was cut, re-welded and clearly gusseted with my factory warranty.
First oil change I ever let some else do in my life of owning any vehicle and I get the new guy at the ford dealership who breaks the louvers on the driver side. They used a pick to remove it I was told. so A week later my girlfreind gets in the truck sticks her feet up and destroys the pass. side so now I need to get it out to see if I can repair it I see how the assembly pops out but how do you disassemble the louver from the assembly. Or is it one piece?
