Installing pioneer nav... Any suggestions?
had a 910bt in a 4 runner, only suggestion is you can probably use the stock ford sirius antenna by modifiing the connection at the sirius module, I have done this several time with xplatform systems XM>Sirius and visa versa.
Make sure you check out any lockout mods so you can engage the dvd/nav input while driving. Probably grounding out one of the pins.
anyone have any input on the power wire placement? I have a help write up in Multimedia/nav.... https://www.f150online.com/forums/mu...r-wire-go.html
Hey all, I finished my install earlier today in this wonderful 107 degree heat. Anyways, as can be seen from my previous post i had some issues finding a place to splice for power. I ended up pulling the coin holder (non 4wd) and finding a hot wire that i cut into and spliced. Much to my suprise it worked great! I accidently found it too, I was about to break down and send it to the audio shop to have it done. Also, i used the Metra kit that everyone said i shouldnt use.... well, it looks alright (keep in mind this is a major upgrade for me to have double din nav) but not factory. I may look into the other kit everyone on here has talked about later on it the Metra starts to bother me. As far as the AVIC x920bt.. great so far!! I have only messed with it about 2 hours now, but it seems to work great!!! The Bluetooth if amazing in my opinion, (didnt have sync to compare it to). ANd i lok that i can controll Pandora when im hardwired into the unit. As far as the Nav goes, i havent taked any trips yet to judge it yet, but it cant be much worse than my out dated tomtom. Anyways, here is a pic as of now.... its not a great pic, but it just so much easier to snap some shots with my iphone and not pull out my dslr. Enjoy!.... also for you audio guys, Bestby near me has a set of 5x7 alpine 7 series (does that sound right) for $39 marked down from $99... would those work for my door speakers? and if so, is that a good deal???
Texas, I'm a little curious about the Nav antenna. Did you truck have Serius prior to this install, and thus, had that antenna above the front passenger's seat (on the roof of course)? If so, were you able to use that antenna for the Nav antenna, or did you have to run a separate aftermarket antenna? If at all, how was the plug different from the old Serius to the required Nav input for antenna?
----hope this helps.
