Project Update
Project Update
Got my new wheels and tires installed today. 18x9 Method Wheels with 275/70r18 BFG AT's. Rides great, definitely takes the bumps better then with the stock 20's.
Very happy with wheel offset and over all look.
Any thoughts on tire pressure with this set up. Thinking 45lbs in front and about 38lbs in rear empty then add as needed.
Thanks,
Thanks,
http://www.nitrogentiremachine.com/p..._inflation.htm
Go ahead and scroll down to the bottom in the "CHECKING TIRE FOOTPRINT WITH A CHALK LINE" section. That will give you the best psi for your truck with your tires
