anyone with a leveled 2wd...
Howzit SUPERSIX.
Check out my member page for pics of my 2010 FX2 and discussions I had through the process of leveling it.
Tried the 2" front lift kit first, no good at all. Control arms hit the coils when ever I went over a speed bump or similar. Decided to try Bilstein adjustable, much better.
Had it custom aligned at a local shop after the leveling but still getting some outer tread wear on the Coopers. Took it to Sears to have them check it and they wouldn't touch it. Was told by 4Wheel Parts Performance shop that the truck needs a camber alignment kit.
Just going to turn the tires on the rims to see if I can squeeze another 18-24 months out of the rubber.
Good luck.
Good luck.
I can't even begin to imagine what your work life must be like if that title is "hostile and insulting". HR must hate you and all of your complaints
