Broken Fuel Door Hinge Assembly Part Number?
Anyone have the part number for the black fuel door assembly (not the outside cover) for a 2010 Extended Cab? FordParts has a couple of different numbers and I don't want to order the wrong one. Plus, how hard is it to remove? I saw some clips from inside the fender, but after removing the bolts from the filler neck I couldn't get the assembly to budge. Was going to pull it and see if I could fix the hinge (door won't stay closed so I used some rare earth magnets to temporarily keep it closed).
It only takes about 10 minutes to remove. remove the 3 screws from inside next to the filler tube, then gently pry out on the rear of the black plastic part using a plactic trim tool. Then push the 3 clips in from behind the fender well. Its kind of a pita but once you get it started at the rear, it will come right out. If you give me the last 8 of your vin i can get you a good part number.
