Shorter antenna?
This is the info I needed. I was gonna get a stubby cuz the factory antenna is crooked and gets snagged on tree branches often. I was pretty amazed with the reception from this antenna, however, so I have yet to replace it. Now I think I will if the stubby still gets good signal.
I know its not as fancy as the stubby from Craven, but I actually just bought a 13" black "shorty" antenna from PepBoys. Looks more like the stock antenna but shorter and not spiraled. $10. I honestly don't know anything about the reception yet as I really don't listen to the radio hardly at all. Just got tired of the super long stock one.
I *just* bought a Harley Davidson antenna based on the recommendation of another member on the other forum. It was about 20 inches long which was great because it wasn't as short as those stubby ones but also wouldn't clang against the garage every time I drove under a sign. But then it arrived and needed an attachment from AutoZone.
Turns out that AutoZone has the little gender-changer adapter but it's only included with an antenna. So I bought a $10 antenna that was 14" long and am using it instead of the Harley Davidson version. I'll return the HD one for my $45 back since the $10 AZ one doesn't have any reception issues.
-John
"Will It Fit" Feeler
I've put a slightly shorter antenna on in the past.....sometimes the using the stock one....removing the ball on the end, cutting and resoldering the ball back on.....
....But I keep it 1.5"-2" or so longer.....to act as the first thing to hit when going in a parking structure....better to learn earlier than later that the truck fits.
I also measure the overall height of the truck....once lift kits and taller tires are added....so I can compare with the helpful "No vehicles over XX inches" signs....
Northlight
Northlight
