Will the ring and pinion from a 2009 f150 fit in a 2012 f150?
This is conflicting data with what I've found so far. What I've found so far is that in 2011 Ford went to a larger pinion bearing in the rear end.
Because new gears are only available from Ford and they are $500. These gears only have 35,000 miles on them and are a $100. That's why I'm not buying new.
