285/70-17 tires?
285/70-17 tires?
Hi all!
I have 245/75-17 tires on my truck now, and when it's time to replace them, I am thinking of going with 285/70-17's (on the stock 7-lug wheels). That would be swapping a 31.4" tire (OEM) with a 32.8" diameter tire, or 663 vs. 635 rpm's (revs per mile). That's a 4.4% difference. Would I notice? Would anything be negatively affected?
I have heard conflicting information - including:
- that 2011 and 2012 trucks with the EB engine can't change tire sizes at all,
- that I can only change to something that's also an OEM option and the computer needs to be re-programmed
- that it's not an issue at all.
Does anybody know for sure? Even different dealers seem to say different things. Has anybody here done this?
Thanks a lot!
Thanks a lot!
toooo many people running wider and taller with no issues. i think people just like to stir the pot so they put out some questionable information. it will just slightly increase the load and that can't have any real impact on a truck.
on the speedo reprogram. i'm running 285's on raptor wheels now and i was told they just programmed it close as they could and i was good to go.
You can put them on just fine, and you can go all the way up to a 295/70 tire and have no rubbing issues. My 5.0 lost around 2 mpg when I swapped from the stock tires, and the speedometer is a few mph off. Any dealer can recalibrate your speedo and I believe its around $100. It is not required, but if you want the needle to match your actual speed it needs to be done.
My truck with the stock tires runs 3% slower than the speedo reads. Most stock cars run a little slower. So you will likely be driving 1% faster than the speedo, which is negligible.
Is your truck 4x4? If so, as mentioned, you can go up to a 33" tire. If not, stock is as big as you can go without as leveling kit.
I went from the OEM Hankook Dynapros from the dealer to a set of 295/70-17 Nitto Terra Grapplers. Definitely heavier but I don't remember by how much.
The 2mpg loss is a rough estimate and that also includes a level and a heavy steel brush guard.
Oh. That makes sense now. If I looked that up correctly, then you went from a 41 lbs tire to a 56 lbs tire, that's a 36% increase. I can see the the 2 mpg drop. Thanks a lot for your input.
