Cost to replace stock differential
If it was my truck, I'd look for either an aftermarket E-locker, Air locker or just go with limited slip. For the cost it's going to cost to convert a factory locker, i see it being more feasible to go aftermarket.
I have about $1100 into my ARB air locker (& ARB HD compressor), but only $325 into my mechanical locker. It all depends on brand and use you are looking for out of the product you choose. To me, the $1100 was worth it. My mechanical will be pulled eventually for another ARB.
What are your reasons for thinking you need the locker?
I drive on desert gravel roads with a little bit of sand from time to to time. I guess I just want to have a better chance of not getting stuck.
What is the best bang for the buck (LS, mechanical locker or selectable )?
Just depends on what you think fits your needs. I'll never put a mechanical locker in a vehicle again, to me a selectable is worth it but to you it might not.
mechanical is cheaper, but on road manners sacrifice.
Selectable is more expensive but on road manners stay the same, while offroad traction improves. Also less strain on the rear axle due to it being open diff 99% of the time
LS, good on road manners and decent off road manners.
A L/S on a two wheel drive vehicle will probably fit your needs.
Every vehicle I've owned has had a L/S rear end, except for my Super Beetle.
Borned and raised on a farm back n da day and all our trucks were 2 WD with L/S (Posi-Traction) and they performed really well. (4x4 trucks were rare back then)
If we did run into traction probs, we just threw on some tire chains and problem solved.
My 78 E-150 had L/S and even with going thru a couple of blizzards while traveling, never had a problem but I did carry a set of tire chains.
I have looked at this on Ford 8.8" Eaton Detriot TrueTrac 913A561 | 31 Spline
http://www.drivetrainshop.com/Detroi...at-913a561.htm
Is this a good unit?
