backup light options
I also have one I install in the 7-pin, picked up at farm and fleet. I don't normally leave it in, cause the first one was stolen. but when I know ill be camping, out and about with a trailer loading later on. ill put it in, and then toss back in truck when trailer is on.
I also upgraded to LEDS for backup lights. and they do help. but nothing like 50watt halogen.
Does the dual light setup require you to leave the receiver in at all times? Or can you move it and leave the lights?
The single 7pin connector light was twice the size I was hoping for and was 35wt vs the dual which was 70wt.
Debating on the two now.
a little off topic, sorry...
I'm new to the forum and joined because i'm having some trouble with my KC Aux Backup lights that I installed about a year ago. I hooked them up to my reverse lights using the relay that came with them. They worked fine for a little over a year, and then on New Years Eve a friend told me that my back up lights were on, although my truck was in park with the ignition off and the keys in my pocket. When I started my truck and put it in reverse, the lights would go off, but then back on when I put it in any other gear (P, N, D). I couldn't get them to turn off so I just unplugged the power. Now if I plug the same wire back in that I disconnected, they don't work at all... Any ideas? Maybe lost a ground? I don't know a whole lot about wiring so before I crawl under th truck (in the snow) I wanted to see if anyone could diagnose what might be wrong based on the series of events that took place.
Thanks!
Thanks!
Maybe
Thanks!
Thanks!
Is it under the hood, or back near the backup lights?
If I had to guess right now from the above, I would say that the relay has road salt on it and that could be causing the problem
