Need quick answer how much oil 09 4x4 with a 5.4
Whats your reasoning behind this? Anywhere in the hash marks is okay but I would preffer to be near the top incase I burn a little? 7 Quarts just got into the hash marks the extra half put it about 1/4 of the way from the top of the hash's? Plus it works out great that I buy 2 5 quarts and in between buy one and use the left over from last time?
The dipstick is an approximation. When you change it using 7 quarts, mark where it hits the dipstick. That is your full mark.
As far as Fram filters, they have crappy anti-drain back valves. Many after an overnight shutdown get valve clatter until the oil gets back to the top of the engine. That is a dry start and will lead to wear. The MC and others, like Wix, Purolater have much better anti-drain back valves.
