Anybody else notice this on their F150?
First off, my truck is a 2009 with a 5.4L, 3:73 gears, 6"lift, and 35x12.5x20 Toyo MT's on it. Here is what I have noticed on the past few road trips that I have taken;
If I set the cruise control and remove my foot from the accelerator pedal it will downshift on a hill of any size. It generally downshifts directly to 4th anytime it downshifts and then comes back to 6th after the hill.
However, if I set the cruise and apply just a little force to the pedal, it will pull like a champ without downshifting. By applying a little force to the pedal, I mean generally somewhere around 10 - 15% according to my EDGE CTS. Then if it does downshift it will only drop one gear and not two. Sometimes as little as 5% of the pedal is all that is required, but it must be applied ahead of the hill or increase in load. It is never enough to pickup any speed before the hill, but just show up on my CTS.
I wish there was a way to get the truck to act like it does when my foot is on the pedal all the time. Anybody else notice or tried this?
Yep, similar results in Tow/Haul. These are hills as small as overpasses that occasionally cause the truck to shift so I'm not talking big hills.
Sounds like I can get some relief by working on my custom tune some more.
Factory tune does the same thing.
Essentially in cruise: you hit the base of the hill, vehicle decelerates a couple MPHs, the computer senses that you've slowed down, and it will down shift to accelerate back to set speed. But unfortunately you're headed up hill by this time, so it really has to down shift and wind up the RPMs to get back to speed while going up hill. The system is reactive based on what has already happened to the vehicle.
If you see the hill coming, and you can over ride the CC by slightly accelerating at the base of the hill, the truck can maintain the speed just needs help with the transitional phase as it "learns" the grade of the hill in terms of engine load. By helping the system ahead of time you are being proactive
Mine is the same way, same size tires, same gears.I have vmp tunes on my sct and have made multiple attempts too get this fixed and Justin ignores my emails now.he did make 2 revisions on my tunes but just made it worse.I wish I could get a tune that would fix it as well.I am very disappointed with my $500 Speedo calibrator and the customer service I received from him, so if anyone gets a fix I'd love to hear as well. I mean it's awful how bad it affects the mpg in cruise.
