tpms relearning drill on a 2011
has anyone had any success in training the sensors to communicate with the tpms system?
i put some new after market wheels on my truck and got the tpms warning. i did the enter the system, let the air out of the tires drill a half dozen times with no luck. went to the dealer and they chuckled about that and says it doesnt work and went and got an electronic tool and in a couple minutes had it done in a couple minutes.
The sensors are after market. Would not learn with the let the air out drill but took two minutes with the tool at the dealer so that shows they are compatible
They may be compatible, but that does not mean they send the same signal for the relearn procedure. My guess is that the AM sensors are made to work with 09 up. The 09 requires the reset tool. That is the procedure for those sensors, even OE.
on
If they are the aftermarket universal oro tek sensors you must jack your truck up and disinflate your tires. Re-inflate your tires and the sensors will wake up, Run the tpms procedure with the tpms trigger tool and the sensors should link to your truck.
The universal sensors are mainly off and are turned on mainly by air pressure change. Hence why they'll alert you of a psi drop in your tires. Makes sense and worked for me.
