Transmission Gear Indicator Lights in "Truck Apps" Mode gone missing??
All, I have a 2013 Plat 4x4 Screw and have noticed something strange. When in "Truck Apps Mode" in the smaller Instrument Panel LCD screen, there used to be gear indicator numbers with the current gear that you are in lit up and slightly larger than the other gear numbers. The indicator would light up the various gears as the tranny shifted through the gear range in Drive. This display has since disappeard and I can't find mention of this in the OM... Anyone else have this issue? To clarify, this is not the display that comes on when you are in the manual shift mode (button on side of shift lever) but it used to be on all the time (not just in 4x4, etc.). Not the end of the world for sure, but it was kinda cool and I'd like to figure out how to get this back if possible.
