5.0 Engine/Coil covers/K&N CAI
Another member over at f150forum had the OEM O-rings mic for size. He came up with 3/4 ID x 15/16 OD x 3/32 Thickness. I measured one on a flat ruler and that should be correct. The Dorman O-rings are about 1/16" smaller OD. And the OEM ones are much firmer when you squeeze down.
Solution
Here is another solution/option to leaking connectors I posted in this thread.
https://www.f150online.com/forums/20...stalled-4.html
Gates vs Dorman 90 quick connects
Dorman 90's with the OEM O-rings did fine for 28 days no leaks and I decided to buy some 90's quick connects from Gates #28505 just to test these and their quality. The gates quality is definitely OEM and the O-rings are the same as the Original hoses. I currently have them on my truck testing them to see if they are going to leak or not. 8 days and so far no leaks.
