325/65R18 w/ 6 inch lift--what backspacing?
I have a 2013 f150 4wd that I am lifting with a basic bds 6 inch lift. I want to run a terra grappler 325/65R18 but I am torn between using a wheel with 5"(0 offset) or 4.5"(-12 offset) backspacing. I do like the aggressive look of a negative offset but I am wondering of a 4.5"(-12 offset) will result in aggressive rubbing. Upon searching I only see older body style f150s running this setup. Anyone running a 325/65R18 on a 2009 or newer that could get give the pros/cons of either setup?
After doing some further research I think I'll be ok with the 4.5" backspacing. Theres a ton of guys running toyo and trail grapplers 35x12.50s with the 4.5" back spacing with no issues. Those tires are actually taller and wider then the 325/65R18 terra grapplers I want to run. I guess we'll see how she goes.
