Trailer plug fuses......??
Rented a trailer this morning and the lights on the trailer worked fine, then qiut working. The rental guy said no power is coming from the truck plug,,,,,HUH?
They worked a minute ago........Went to the owners manual and found nothing to work with. I remember my F350 had a separate fuse box for the trailer plug. I believe he shorted something out when he was playing around with the plug, it always seems to be a problem with rental places, they always seem to want to work on the stuff you are renting when you get there,,,,,
Any suggestions?
Any suggestions?
I just dealt with this yesterday with my boat trailer. Mine truck is an 05 with the trailer tow package so not sure if it is the same. There should be a mini fuse for a left turn and right turn trailer and another mini fuse for trailer park lights all located in the main fuse box. This is the second time in as many years that I've had to replace the park light fuse so I put in a little bigger one to see if that does the trick.
Owner's manual is a little vague so you might have to just check some that might fit the bill.
be careful putting in higher rated fuses... a short in a trailer wire could overheat the truck wiring and cause major problems.
Yea I hear ya, I just went up one size of fuse so things shouldn't ever get hot. I think I have a wire in my trailer that may ground out when wet, we had the trailer in the water for some time due to high winds while loading the boat. I think from now on I will just unplug the trailer before putting in the water, usually do but got lazy.
