NEED ADVICE!! Leveling Kit for 285/75/17 tires.
Hey all. I have a 2011 supercrew 4x4 6.5 ft bed. I am going to be getting some 285/75/17 tires. I have the stock 17" wheels. I was wondering what leveling kit to go with. I like the 2.5" autospring but I am concerned about the control arms rubbing. Also, my truck has a canopy on it so I am torn on which kit to buy. Autospring has a kit with rear blocks, and they have a kit with an AAL. I am not sure which one to get. I think the AAL would be nice because of the extra weight of the canopy and I do occasionally tow about 4500 lbs. But I don't think I will get the same lift with the AAL that I would with the blocks.
Thoughts?
Thoughts?
Thoughts?
Thoughts?
He also told me that up to 34s shouldn't be a problem as long as not real wide. 285/75R17s are 11.22" wide (and 33.8" in diameter); the 275s I have are 10.83" wide, so that's a .4" difference. Doesn't seem all that much.
Yes, I'm aware that truck rakes vary. I'd recommend calling Kevin to get his input. He's as talkative as he is knowledgeable.
208-362-0431
800-345-0431
Let us know how it goes.
I am going to go with the Toyo Open Country AT II. I have had really good luck with Toyo Tires. I was/ am still kind of debating on getting the 285/70/17. Because they are 13 lbs lighter per tire, and slightly smaller so the revs per mile are closer to the factory tires. But I like the fact that the 285/75/17 have a 3 ply sidewall like the MT's do, and they have more shoulder on the sidewall.
