Lift suggestions for my 2011 F-150 Limited
I have a 2011 F-150 Limited, I put 33" Nitto Terra Grapplers on it with a leveling kit to raise the front end. I'm thinking about going to 35" tires and am looking for a 3'' Body lift. This is my first time lifting a truck, looking for suggestions. I still drive it daily, so 35" is the max I want to go.
The best body lifts for the 08 and back trucks are the Performance Accessories (commonly referred to as "PA" in other posts), so I assume the same goes for the newer trucks as well.
2WD or 4WD/AWD? If 4WD, you can stuff 35's in there with just the level if it is a 2.0 to 2.5".
Do you have the stock wheels? On 04+ trucks, the body lift installation process is very labor intensive, and therefor expensive if you can't/don't do it yourself. If you have aftermarket wheels, I'd just go ahead and get a proper 6" lift kit that will give 6" of lift vs 5" from the level and body kit because the end cost after labor won't be too far off. Most lift kits are not compatible with stock wheels, that's why I ask.
