2011 f150 lift and tire suggestions pleade
Hey folks I have a 2011 F150 Fx4 I'm going to be putting a 2 1/2 front 1 1/2 rear auto spring lift level kit in. I'm curious what you guys are running for Tires brand and size. I'm want a bit bigger and an semi aggressive tire. Right now I'm sporting the stock 275/55/r20 pirellis. Any input is greatly appreciated
Don't know that that is a fair comparison between your tires. You went from an E rated LT tire to a P rated tire. They are lighter because they are 6 ply instead of 10 ply, and they are also narrower. 10.5" wide versus 12.4". So yeah, doing that will shave 30 lbs easy.
I don't think he was comparing, pretty sure he was just stating a fact. And they're about 14 pounds per tire lighter. 30 is a little extreme.
OP, toyo and nitto are both great brands. If you arent doing any hauling or towing you will be fine with a p tire. The LT tire has more load capacity and less flex, although it will be a bit heavier as mentioned above. if they are going on stock rims a 275/60-20 (33 inch) tire will work and look great. The toyo at, toyo at2, or nitto terragrappler are all great choices. From my personal experience, toyo will slightly outlast nitto.
I put a 2" lift all the way around on mine and I am runing 295/70R18 (They're just a hair under 35" tall) Nitto Trail Grapplers and I love the stance and the traction.
I ran a 35x12.50R18 ProComp xTreme AT on my old 04 F-150 with the exact AS kit you are buying and had zero clearance issues with them.
