Tick noise related to HVAC blower?
Vehicle: 2012 XLT SCREW Ecoboost
I have a weird tick/rattle noise in my truck. When I first heard it I thought maybe the radio antenna was loose and rattling. I checked it and its tight (but this gives you an idea of what kind of noise it is).
Since then, I have realized that it is in the HVAC system. It only makes noise if the blower is on setting 2 or higher. If you put it on the lowest setting or off then there is no noise. (I have tested this many times over the past 2 weeks)
It does not seem to matter which direction the air is going (top vents, bottom vents, etc).
Has anyone else had this issue?
I'm wondering if maybe there is something loose in the ducts by the blower motor and the air flow is making it rattle, in conjunction with road bumps.
I'm planning on pulling out the blower motor and seeing what I find. But I thought I'd ask first.
(and yes, I know its still under warranty... but it will probably be quicker & easier to just check it myself first)
oh, and I did search first... in this forum and in the HVAC one. The only thing close to what I have is this
https://www.f150online.com/forums/20...-question.html
But that seems like it was a different noise. And there was no resolution.
So the blend door actuator was broken?
Were there any other symptoms that I could check to confirm this?
I still haven't had a chance to dig into this... but if its likely a broken part maybe I'll save myself some time and just take it to a dealer (under warranty).
ya, that could be it.
