Help with 12 platinum wheels and tires
Old 11-12-2013, 01:21 AM
Willsmith1234's Avatar
Originally Posted by KMAC0694
I literally haven't laughed this hard in SO long, I'm crying!!! Whew, okay . . . MGD started calling me it and the "redneck defynision" is in his signature
But anyways, I think a 295/60/20 (33.93" x 11.6") is just about the perfect size for a leveled 4x4 and I doubt you'd have any issues rubbing with the +1 offset. People throw "35s" around for a lot of tire sizes, when most aren't a true 35" tire. ~34"+ is pretty much a "35"
These are what 295/60/20s with a 2" level look like, albeit on stock wheels:
http://www.f150forum.com/f38/nitto-t...136774/index8/
https://www.f150online.com/forums/wh...s-oem-20s.html
I think they fill the wheel wells perfectly
Thanks! I think this is almost exactly what I'm looking for. I've also seen 12.50 thrown out there...that's just a little wider, not taller, correct?
Old 11-12-2013, 02:15 AM
Correct. That 12.5 refers to the width in inches. The size 35x12.50x20(or 17, 18, etc) is pretty much the super generic size for a full 35" tire. The English units for the tires makes sense: 35" tall, 12.5" wide, 20" wheel. The metric system is stupid and complicated lol. I believe a 315/60/20 is the best metric equivalent of a 35x12.5x20. So these 295mm wide tires are going to be a little bit narrower than 12.5". Your truck will look very similar to those, just with the wheels sticking out some more. But I think 295/60/20 is a better size unless you have a full lift because a full 35" tire can look too "stuffed" at times.
Old 11-12-2013, 02:38 AM
was asking because i was hoping to put the mickey thompson baja atz on there and they don't have the 295/60. i definitely like the height of that one though. back to the drawing board. thanks again!
Old 11-12-2013, 02:56 AM
This makes me think you'd be fine with those ATZs
http://www.mickeythompsontires.com/t...=BajaATZRadial
34.5" is a touch smaller and the tires being all terrains and not muds helps a lot actually. I apologize for jumping to a mud tire. You can always run a different tire too, and there are plenty of sizes that look good. You can run the 20x10 wheels with the -12 offset like Deacon and just run a slightly smaller tire too. There are a million different options, but that's the problem!
Old 11-12-2013, 03:10 AM
haha, no worries. i know i like the taller tire and for sure doing a 20" rim. I like the +1 offset to push it out just a bit. Thinking about 35x12.50x20 20x9 +1 and doing those mickeys with black rims....i'll keep ya posted. thanks again!
Old 11-12-2013, 09:20 AM
jdeacon's Avatar
I feel so.... enlightened haha but seriously that was hurting my brain
Old 11-12-2013, 01:31 PM
onebadfiveoh's Avatar
This has been an AWESOME thread to read through!!! LOL! Once again, plenty of good knowledge being passed around with a decent helping of comedy. Thanks y'all! I need that today!
Old 11-12-2013, 01:32 PM
Originally Posted by jdeacon
Who the Hannah is The Ombudsman lol and do I need to find a cool name and start referring to my self in the third person?
This is the one that did it for me too.... HILARIOUS!
Old 11-12-2013, 02:56 PM
Do you mean trying to understand his definition was hurting your brain?
Sounds good
Old 11-12-2013, 03:03 PM
jdeacon's Avatar
that is what were here for!!
no lol just what the word meant. reading his posts hurt my brain. the next time i get super drunk im going to long on here and see if they are any easier to read haha
Old 11-12-2013, 03:44 PM
RedWoodsMan1's Avatar
That's a good look, and may be right up the OP's alley due to the amount of daily miles traveled. 35's will likely require some trimming with a 2" and will look stuffed in there. And as others have mentioned your performance will suffer without some gearing adjustments. Will - I look forward to seeing pics of whatever you decide!
Old 11-12-2013, 05:44 PM
MGDfan's Avatar
W.T.F???
Oh.... now, that's cold!
Old 11-12-2013, 07:42 PM
jdeacon's Avatar
Originally Posted by MGDfan
W.T.F???
haha it breaks up the monotony! and i myself am from a one stop light town, where the towns around me all had graduating classes of ten or less and i still have to reread some of the words! but i welcome the challenge! it reminds me of the brain tricks where if the first and last letter of a word are in the correct spot, all the other letters can be switched yet you can still read it just fine!
Old 11-13-2013, 01:42 AM
Believe, that'll just make it worse! And then all the stuff you write won't make sense the next morning haha.
It's so much more work to write in and read hillbilly speak than it is normal English!
Old 11-13-2013, 07:18 AM
MGDfan's Avatar
Dern tootin' she be mer work, son!
Shootin' hell fahr, befer ah know'd nuffin aboot 'putin', I wuz afeered o' the boogerin' thangs, whut wif all them danged wahrs, transvestites, ellie-D's, whirrin' noises, operatin' cisterns an' sich.
Then - ah found me sump'in thet made mah shrivel'd hairy ol' twins a'twitch fer joy:
Now, I kin, fer fair, type wif my faverite one-finger'd a'huntin' & a'pekkerin' style till mah bless'd Bessie come home!
Lawdy, ah be a happy ol' Wiccan coot now, thankee be ta the Great Pumpkin!
Quick Reply: Help with 12 platinum wheels and tires
