No servicable fuel filter???
I change my fuel filter once a year, it's always got brown coming out of it, this is a cheap *** thing to do. Especially when you have no gas cap!
The same people that never change their oil. It makes no sense to design products with that mentality. How well do the 100k spark plug life cycles work out on the 3v engines?
Maybe, but you know it's most likely true.
Quit the contrary, why do you think Fords engineers design the vehicles to start out in third gear on manual cars and put in a very conservative tune. Because they know there will be plenty of idiots driving them.
I wouldn't know how long the 3v plugs lasted, I traded mine in with 39K
Nice of them to acknowledge R&R would be a real good idear at some point, lol.
MGD
Y'all do realize there is a reason for moving the filter.
When the filter is halfway down the line all the junk has to run through the pump. All that trash wears the internal parts of the pump out and they get mixed in with the fuel and pumped to the motor. If you were lucky the filter caught most of it. If the filter is before the pump the trash is stopped before it gets to the pump and causes damage. Since most cars have the pump in the tank the filter has to be there too. To deal with this most manufactures have added an access panel to the tank to pull the pump and filter out.
Still, on a pick-me-up, it's a PITA to drop the tank or remove the bed to get to that panel.
Wouldn't be difficult to add an in-bed access hatch over the tank to help facilitate this, if they weren't so adamant that it was a 'lifetime' part, hence no need fer said access. ( Like 100k plugs, lifetime balljoints, lifetime trans/diff fluids, etc . All TCO crap, imho.... )
Hell - isn't that where Ridgelines had their jack/tool compartment - which was inaccessible when the bed was full of mulch. Oops,
EDIT: Does an EB truck have any sort of supplementary filter for fuel? I'd reckon the high pressure injectors would be more prone to damage from particulates than the 'normal' 40 psi variety. Especially after the original in-tank unit has been in service fer a few years.
MGD
