No servicable fuel filter???
#31
...EDIT: Does an EB truck have any sort of supplementary filter for fuel? I'd reckon the high pressure injectors would be more prone to damage from particulates than the 'normal' 40 psi variety. Especially after the original in-tank unit has been in service fer a few years.
MGD
MGD
#32
[/QUOTE]Since most cars have the pump in the tank the filter has to be there too. To deal with this most manufactures have added an access panel to the tank to pull the pump and filter out.[/QUOTE]
But you still have to drop the tank... it's a PITA
#33
Thats bogus. How many of you have had a fuel pump failure? I have had a ton of trucks (40+) for my company and personal use since Ford went to fuel injection in 1987 and never have had to have but one replaced, and it was an '87 that had 2 fuel pumps, a low pressure one in the tank and one in-line (stupid system by the way... they did away with after a couple years). If this was a real problem, it would have been addressed eons ago. The fuel filter in the tank, at least on the ones I have seen is not a sock, but more like a fine metal screen
Nope, not on most cars on the road today. Almost every car/suv out there has an access panel in the body to get to the top of the tank where the pump is. The last pump I changed out was on a VW Passat and it took about 20 minutes. That included the time it took me to find some plastic to lay down in the trunk so I didn't spill any gas on the carpet. On a truck it will be more of a problem since people don't want a hole in the bed.
