No servicable fuel filter???
You should be fine short of the contents of the fuel tank becoming quicksand.
If the choice is between old style setup and the possibility of getting garbage all the way up the lines to the filter versus a sock in the tank blocking things off, I'll take the chance on the in-tank filter doing the job.
on
not true.....gm removed the fuel filter in the gas trucks and rely on a sock on the fuel pump pick up tube in 2006-2007 depending on the model....so they beat Ford by a couple of years on that one....
