New 2014 F150 Ecoboost with 2.5" Autospring Leveling Kit & 35's
#31
I wish I could get mine to look like that. I tried, but ran into a seemingly unique issue. Did you have any issues getting the shocks back in the lower control arm? I know this /should/ be a simple job - but I spent 4 hours trying to pry the shock back in and couldn't get it to budge. It simply would not compress to get into the pocket.
The only other option I saw was to remove the entire knuckle from the LCA so the arm could go down lower. I wasn't prepared to do that on a Sunday night - especially since nobody else seems to be having this issue. The 4x4 axle seemed to be limiting the travel.
Fortunately, this was on the first/drivers side, so I just put it all back together to regroup.
#32
#33
That was the next step - but we were 4 hours in and running out of daylight. And I was frustrated b/c in every freaking video, its wham, bam, thank you ma'm for putting everything back together.
There was even one vid (daystar I think) that they didn't even pull the shock out! It stayed connected to the lca.
Thanks for the info - I read the instructions for the autospring. Interesting they say you only need to pull the front bolt out. We'll see.
#34
I also have something better than floor jacks and jack stands to work off from, so that makes most jobs easier as well.
#35
Took about 4 hours tonight. I cheated- I wish I would have purchased the autosprings now since I had to use their instructions. In hind sight, it would have been worth the $20 difference.
Anyway, the key for a 2013 (at least) is to pull the front bolt out of the LCA to be able to get that shock back in the pocket. Once we did that, I used the BFH to force it in, and things went back together nicely. It would have been a bit shorter, but we had to go fishing for a shock nut that fell.
Front and back sit at 39" now. It was at 36.25 and 39. I hope the front will settle a little bit after getting aligned. Now, I need to figure out what tires to get. I'm thinking 275x65x20 to get a nice aggressive pavement princess look. It's only got to get the boat up and down the ramp. I'll see if I have enough juice to post pics tomorrow when I can take some more pics.
#36
