Need Help with Brake/Signal Light
Need Brake/Signal help please
Ok I have a 2011 F150 5.0 fx4, my trouble starts with the fast blinker and no brake light on the right rear only. Things I have tried are, checked all applicable fuses/relays, changed both bulbs (twice) changed bulb receptacle from left to right so those are good, checked multifunction switch and cable harnesses for loose wires, ended up changing the multifunction switch because im running out of options. Problem still persists.
on
The MFS cannot cause this symptom on a 2011 since the brake/turn signal doesn't go through the switch.
There isn't much more a DIYer can do without the diagrams.
Can you tell if the relay for the RT lamp for the trailer in the Battery Junction Box works when the right turn signal is on? If it does, you probably have a wiring fault. If not, it's probably the Body Control Module.
