Transmission Fluid Exchange and Rear Diff
is ELD and "Traction-Lok" the same thing?
from the 2010 owner's manual:
Rear 8.8/9.75 inch axle fluid
5.5 pints (2.6L)
Motorcraft SAE 75W-140 Rear Synthetic Axle Lubricant
XY-75W140-QL / WSL-M2C192-A
Service refill capacity is determined by filling the axle to 1/4-9/16 inch (6-14 mm) below the
bottom of the filler hole with the vehicle on a level surface.
Add 4 oz. (118 ml) of Additive Friction Modifier XL-3 or equivalent meeting Ford specification
EST-M2C118-A, for complete fill of 8.8 inch and 9.75 inch Traction-Lok axles
Your vehicle’s rear axle is filled with a synthetic rear axle lubricant and is considered lubricated
for life. These lubricants do not need to be checked or changed unless a leak is suspected, service
is required or the axle assembly has been submerged in water. The axle lubricant should be
changed any time the rear axle has been submerged in water
5.5 pints (2.6L)
