Throwing codes for cylinders
I have a 2011 F150 SC with the ecoboost. I keep getting Diagnostic code for cylinder misfire. Changed plugs and still does it under loads at time. moved coils around and will still throw a code on those cylinders. Any advise? Truck has 116,000 and has been doing off and on for thousands of miles.
Curious on what oil you are running. My nephew went outside the stock parameters and had the same issues. Changed plugs, swapped coils etc. Was going to tear down the fuel rail, but did some additional searching. It seems if you aren't running synthetic and the right viscosity it can hamper the cam shaft revolutions and mess up firing etc.
I am no expert, just sharing what my nephew went through, He did an oil change and it helped, and after about a week everything was back to 100%.
