Tire question?
Tire question?
I have researched and researched and I can't find an answer to my questions. I have a 2014 F150 4x4 crewcab with 20" wheels. At first I had my heart set on putting a 1.5" leveling kit on the front, but the more I research it, I am seeing that I don't need to do that because I do a lot of towing, and everything I read says it is not good for towing. Is this true? Also I have read a lot about the spacer leveling kits causing alot of wear on all the components. Is that true?
Now what I am wanting is a more aggressive tire than the stock tires. Can I get a more aggressive tire with a stock setup, or do I need to get it leveled?
Thanks!!
Thanks!!
You will be able to get a aggressive tire but not much larger than what you got on it now. I am running 35 inch tires on a 2 inch leveling kit. If you want bigger tire then level it off. i dont think it will wear anything down so much that it will make you have problems with any level you put on it.
level
I agree with what your saying but once you go to a 3 inch, its not really "level" . 3 inches will make your truck squat just enough to tell sitting still and more when your driving.
We could go about this all day it seems, haha.
Anyway, back on topic.
No that will be all fine. the only thing that will probably need to be recalibrated is the speedometer.
Some other guys can comment on spacer vs coil over replacement on tow performance.
If you stay within say an inch of stock tire size folks I know leave the odometer be.
