in box tie downs
Due to the double-wall bed construction (welded), there is no easy way to retrofit the 2015+ BoxLink tiedowns.
Sure, you can try using blind rivet nuts, but with no additional backing-plates behind where you locate the BoxLink plates (it's improbably difficult, if not impossible like for the front, to put plates back there as the only access is from the bottom of the bed where there is an opening between the outer and inner walls), it probably won't hold any appreciable load safely without the danger of pulling out or warping the un-reinforced sheetmetal of the bed.
