leveling kits!
I got the 2.5" Rough Country. It made my truck almost perfectly level. I'm really glad I went with it. It didn't kill ride quality either. If you do any off roading, I would stick with a Bilstein adjustable 5100 or something similar. If yours is a pavement king like mine, you'll be perfectly fine. Hope that helps.
Didn't screw anything up. I had my friend Replace Lower Ball Joints, Upper Ball Joints, Tie Rods and all that good stuff before I would have any issues also replaced with all MOOG Parts.
My truck has 160,000 miles on it and it is 12 years old so i would have to replace it at some point. Better to do it now then break down on the side of the road.
The leveling kit was perfect for me. I drive a lot and do not go offroad, So it gave my the non stink bug look for under $150 installed with parts.
Not bad compared to $1800 for a lift kit not including tires.
Also blew my tranny just 2 weeks ago which was $1800 to fix, so glad I didn't put a huge lift on a 12 years old truck.
Then i just got my Navigation installed..
Jensen Navigation in my 2004 F150
2014 with a 2" AS level on the front. It measures perfectly level. I have the stock 1.25" blocks in the rear. I just ordered 2" blocks to get a bit of a bump up on the back and have a bit of a rake again. I think I'll be putting Fox 2.0 coil-overs on the front to match the 2.0's I have for the rear (waiting to do the blocks before putting them on). If the 2" blocks don't lift the rear enough, I'll put Pro-Comp AAL's or the 3" blocks I have on the shelf.
Here it is with the 2" level on the front. Pretty much the first thing I did to the truck.
