Power Steering Return Hose Blows Off
I opened my power steering system while doing some collision work. I have now closed the system and have tried to bleed the power steering. Some how high pressure in getting in my return lines and blowing them open. It seems like the full pump pressure is coming directly to the low pressure return lines. When I start the engine, less than 30 seconds and a line will blow off.
Do I have a bad valve in my rack or the pump that is causing this high pressure to get in the return lines? Is their an easy fix or are we in for a new rack?
You're nicer than me. I was getting ready to say something about the problems of putting a hydro hose on an electric rack...
on
^^^ is that doing it right?
You can in here being a smartass, what did you really expect when you either didn't know or forgot that in 2011 the steering rack went electric?
Maybe you should call one of those real mechanics so they can put your hose on. If you're making enough pressure to blow the line off you have something plugging the line or the fittings are bad. Both should be fairly obvious to a real mechanic.
