key nor fob nor keyless pad will open door
My 2014 F150XLT will not open what so ever, the key will NOT turn within the cylinder, the key pad will not register my code, and both of my fobs do nothing. I can not even get into the cab to pop the hood if its a dead battery... the passenger door has no key hole, so I am stuck with driver side door only. Any help would be great
If you have AAA, they can probably open the door for you. Then, you would be able to get to the battery if it needs changing, or, if the truck starts, you could get it to a dealership for repair.
If you don't have AAA, do you know someone with a slim jim? You can also use a screwdriver, I think at the edge of the handle module to release the door lock. (It may damage the door a small bit. Look up JimmiJammer here: http://www.jimmijammer.com/JJ%20desc...0and%20450.htm to get an idea how this is done.)
If none of the above, invite a gang member to break in to your truck. They can probably do it in about 5 seconds.
- Jack
- Jack
