2009 wont shift out of park
Do your brake lights work? If not, that has to be fixed. Fuse or bad brake light switch.
Brake shift interlock bypass is described starting on page 281 in your owner's manual:
http://www.fordservicecontent.com/Fo.../09f12og3e.pdf
Fuses are on pages 314-322, the BSI is F5 in the inside fuse box. Brake light switch fuse is F46 and F76 in the underhood box.
If the brake lights do not work and the fuses are okay, your brake light switch on the pedal is bad. That's what's keeping it locked in Park.
http://www.rockauto.com/en/catalog/f...t+switch,10474
Check all 3 fuses with a multimeter, you can't just look at them.
