2010 4.6 3 valve missing on acceleration
First off, great site! Now, my problem. I have a 2010 with the 4.6l 3 valve. It started off with a rough idle. It went to the dealer who cleaned the injectors. The idle was a little better but still not perfect. Here, 6 months later and got a cylinder 3 misfire. I changed the cop and fixed that. Now, if I'm running a steady speed and lightly touch the gas, it starts bucking like it dropped a couple cylinders. Gas mileage has dropped from 16 to 14. The truck has 140k miles. Plugs were changed last summer with stock Motorcraft.
Sorry for the late response but the truck is back to normal for now. All 8 plugs were bad. The gap had opened to around .075 and all appeared to have been burning hot. The plugs had only been in for about 30k miles. The fuel trims don't indicate a lean condition so I'm not sure what caused them to burn up.
The following users liked this post:
I wish I knew why they went so quick as well. They were stock Motorcraft plugs and the ones they replaced had 120k miles on them. I'm going to keep a close eye on it.
