6 Speed downshift for passing
Think from reading this is possibly normal, don't like it but maybe normal. Only catch is most of what I searched has to do with downshifting on hills.
Went from an 07 Lariat 5.4 to a 2010 Lariat 5.4 and this one has the 6 speed in it. Normal driving etc I can live with it but at 50mph if I nail the truck to pass it literally goes shift-shift-shift.. I'd expect it to drop right to a passing gear but it actually shifts through a couple of gears one at a time. I believe the 5th and 6th are overdrives so maybe it has to go through them first?
Is this normal for pedal to floor passing? In this situation I liked the old 4 speed much better, just dropped to passing gear and took off.
No such thing as "passing gear" - the transmission downshifts one or more gears. What is happening may or may not be normal, but I would *think* the computer should command a downshift to an appropriate gear without doing it one at a time. You may want to check with a dealer to see if there's a software update available.
I've noticed I have better passing performance in my 2014 3.5 EB, if I just smoothly advance the throttle, rather than a sudden "stomp" on it. The truck has plenty of passing power without an immediate downshift, and then if it does, it's a rather fast one-step one.
If I stomp it, there's a hesitation while it makes up its mind which gear to use.
- Jack
- Jack
My 2014 gets "confused" at 50 mph so yeah, it's normal. My 6 speed will shift up out of first trying to pull a hill from a stop with the engine lugging flat on the floor, then goes to false neutral, then the engine spools up, then slams into gear.....and Ford says it's normal. It will bump you in the but at every stop when it's cold and despite the tricky Ford lube for the yolk....Ford says it's normal. I've gotten accustomed to it but frankly, I consider it dangerous. You don't pull out in front of traffic and expect to scoot right along cause it might already be in 6th gear at 20 mph.....but it's normal. The transmission is the only complaint I have with mine. So it ain't all bad.
I can live with it, I miss the instant decisive downshift of older trannys though. More of a 'if it's normal no big deal'.. Would just hate to have the trans blow out 6 months from now and then find out this was a warning sign Rest of it is easily the quietest nicest riding highway truck I've owned and to pull 2 900lbs SeaDoos and still get 18/19 mpg is excellent.
My Mustang tells me the same thing, has the little skateboard shoe light up on the dash.
It's fun to mash the pedal and not go anywhere. lol
